Introduzione
This guide will be helpful for repairing the speaker if the troubleshooting page recommends that you replace it. This is a necessary step when you have determined no other way to repair your current speaker. Be wary of accidentally damaging other parts of the device when replacing the speaker.
Cosa ti serve
Look at the side of the speaker that has the red interface plate. Using a Phillips head PH1 screwdriver head, remove screws on the top and bottom of the black face plate. There will be one screw on top and one on the bottom.
Both screws are 0.55 cm in depth
For the top horn replacement, you will be working with the blue and white wire pair.
For the bottom horn replacement you with the yellow and white wire pair.
Attrezzo utilizzato in questo passaggio:Desoldering Pump$3.99
Use a soldering iron to heat the two contact points.
Then use a desoldering pump to remove the liquid solder.
Altre 3 persone hanno completato questa guida.
