Salta al contenuto principale
AvertX HD810 Dome Cover Replacement
Cosa ti serve
  1. AvertX HD810 Dome Cover Replacement, Clear Dome Cover: passo 1, immagine 1 di 3 AvertX HD810 Dome Cover Replacement, Clear Dome Cover: passo 1, immagine 2 di 3 AvertX HD810 Dome Cover Replacement, Clear Dome Cover: passo 1, immagine 3 di 3
    • Lift off the paintable snap-on cover from the AvertX HD810 dome security camera.
    • Optimally, the device should be turned off and the PoE (Power over Ethernet) unplugged.
  2. AvertX HD810 Dome Cover Replacement: passo 2, immagine 1 di 2 AvertX HD810 Dome Cover Replacement: passo 2, immagine 2 di 2
    • Loosen both 10mm screws on either side of the clear dome cover housing using a T10 Torx security screwdriver.
    • It is not recommended to remove the screws from the clear dome cover housing. The screws are apart of the cover and not intended to come out.
  3. AvertX HD810 Dome Cover Replacement: passo 3, immagine 1 di 3 AvertX HD810 Dome Cover Replacement: passo 3, immagine 2 di 3 AvertX HD810 Dome Cover Replacement: passo 3, immagine 3 di 3
    • Gently pull off the clear dome cover from the camera base.
Conclusione
You've successfully replaced your AvertX HD810 clear dome cover when you've snapped back on your paintable snap-on cover. You can reassemble your device at any point by following the steps in reverse order.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 15
Tutti i Tempi: 719
