Salta al contenuto principale
Autosampler Reset for Node Triggered Sampling (For Old & New Versions)
Cosa ti serve
  1. Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Switch to manual mode: passo 1, immagine 1 di 2 Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Switch to manual mode: passo 1, immagine 2 di 2
    • To enable manual mode, flip the switch to "Manual Mode"
    • LCD screen will turn on
  2. Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Restart the sampling program: passo 2, immagine 1 di 2 Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Restart the sampling program: passo 2, immagine 2 di 2
    • Press On then press Start Sampling
    • Press Enter
  3. Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Select bottle: passo 3, immagine 1 di 3 Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Select bottle: passo 3, immagine 2 di 3 Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Select bottle: passo 3, immagine 3 di 3
    • Press the number of the bottle you want to sample on
    • Press Enter
    • LCD should now show which bottle it will take a sample in
  4. Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Switch to autonomous mode: passo 4, immagine 1 di 2 Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Switch to autonomous mode: passo 4, immagine 2 di 2
    • To enable autonomous mode, flip switch to "Node Trigger Mode"
    • LCD should turn off
    • If the autosampler is to be remotely triggered, avoid using the ON/OFF button to power off the sampler.
Conclusione
Now the sampler is ready to be triggered remotely by an open-storm sensor node.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 414
