Salta al contenuto principale
Automatic Coffee Machine Cecotec Power Matic-Ccino 7000 or Rooma RM-A7 Disassembly
Cosa ti serve
  1. Automatic Coffee Machine Cecotec Power Matic-Ccino 7000 or Rooma RM-A7 Disassembly, Taking Main cover off: passo 1, immagine 1 di 2 Automatic Coffee Machine Cecotec Power Matic-Ccino 7000 or Rooma RM-A7 Disassembly, Taking Main cover off: passo 1, immagine 2 di 2
    • Using a T10 screwdriver, remove the eight screws located on the rear panel of the device (4 towards the bottom, and 4 towards the top).
  2. Automatic Coffee Machine Cecotec Power Matic-Ccino 7000 or Rooma RM-A7 Disassembly: passo 2, immagine 1 di 2 Automatic Coffee Machine Cecotec Power Matic-Ccino 7000 or Rooma RM-A7 Disassembly: passo 2, immagine 2 di 2
    • Unscrew one PH2 screw.
    • Use a spudger or a thin curved tool such as a dental pick to remove the bean hopper of the burr grinder.
    • Remove the grind selector by pulling the dial directly away from the machine which will remove it from the housing.
  3. Automatic Coffee Machine Cecotec Power Matic-Ccino 7000 or Rooma RM-A7 Disassembly: passo 3, immagine 1 di 2 Automatic Coffee Machine Cecotec Power Matic-Ccino 7000 or Rooma RM-A7 Disassembly: passo 3, immagine 2 di 2
    • The Hex screw must be unscrewed in the clockwise direction. Failure to do so could result in damage of the grinding mechanism.
    • Unscrew the one 4mm Hex in a clockwise fashion and remove the black plastic cover over the burrset.
    • Remove the black plastic cover over the burr set.
    • The burr set should not be completely visible.
  4. Automatic Coffee Machine Cecotec Power Matic-Ccino 7000 or Rooma RM-A7 Disassembly: passo 4, immagine 1 di 2 Automatic Coffee Machine Cecotec Power Matic-Ccino 7000 or Rooma RM-A7 Disassembly: passo 4, immagine 2 di 2
    • Unscrew the three PH2 screws.
    • Slide the top panel backwards to remove it.
  5. Automatic Coffee Machine Cecotec Power Matic-Ccino 7000 or Rooma RM-A7 Disassembly: passo 5, immagine 1 di 3 Automatic Coffee Machine Cecotec Power Matic-Ccino 7000 or Rooma RM-A7 Disassembly: passo 5, immagine 2 di 3 Automatic Coffee Machine Cecotec Power Matic-Ccino 7000 or Rooma RM-A7 Disassembly: passo 5, immagine 3 di 3
    • Now you should have access to the internal components of the appliance.
Conclusione
Altre 4 persone hanno completato questa guida.
Egas
Membro da: 09/20/10
181 Reputazione
1 Guida realizzata
Zi repair Membro di Zi repair
Business
1 Membro
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 44
Ultimi 30 Giorni: 179
Tutti i Tempi: 3,341
