Salta al contenuto principale
Audiovox Tri-mode CDM-9000 Battery Replacement
  1. Audiovox Tri-mode CDM-9000 Battery Replacement, Replacing the Battery: passo 1, immagine 1 di 3 Audiovox Tri-mode CDM-9000 Battery Replacement, Replacing the Battery: passo 1, immagine 2 di 3 Audiovox Tri-mode CDM-9000 Battery Replacement, Replacing the Battery: passo 1, immagine 3 di 3
    • Flip your phone over so the screen is facing down.
    • About half way down there is a small button with a few groves. Push this button in an upward fashion. This will release the battery from the back of the cell phone.
  2. Audiovox Tri-mode CDM-9000 Battery Replacement, Remove Battery: passo 2, immagine 1 di 2 Audiovox Tri-mode CDM-9000 Battery Replacement, Remove Battery: passo 2, immagine 2 di 2
    • Once the back piece is released, simply lift the battery up and away from the phone.
    • Replace the battery by placing the bottom part of the battery in first and push down. You will hear a loud click sound when the battery is secure.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 372
