Salta al contenuto principale
Audiovox CDM-8910 LCD Screen Replacement
Cosa ti serve
  1. Audiovox CDM-8910 LCD Screen Replacement, LCD Screen: passo 1, immagine 1 di 1
    • With phone in the flipped-open position, use a spudger to remove the four (4) rubber pads (one shown in red circle) located near the corners of the face with the LCD screen.
  2. Audiovox CDM-8910 LCD Screen Replacement: passo 2, immagine 1 di 1
    • Use a small Phillips head screwdriver to remove the four (4) screws exposed by removed rubber pads.
  3. Audiovox CDM-8910 LCD Screen Replacement: passo 3, immagine 1 di 1
    • Use a spudger to pry the front cover off of the phone, gradually working your way around the front face.
  4. Audiovox CDM-8910 LCD Screen Replacement: passo 4, immagine 1 di 1
    • Use a spudger to lift away and remove the metallic frame (in blue).
    • Use the spudger to lift away the two electrical contacts (in red).
    • Use the spudger to lift away the speaker (in yellow).
  5. Audiovox CDM-8910 LCD Screen Replacement: passo 5, immagine 1 di 1
    • This is what the rear of the LCD screen should look like before proceeding. Note all necessary connections are undone.
  6. Audiovox CDM-8910 LCD Screen Replacement: passo 6, immagine 1 di 1
    • Use a spudger to lift away the LCD screen.
  7. Audiovox CDM-8910 LCD Screen Replacement: passo 7, immagine 1 di 1
    • LCD screen successfully removed!
Conclusione
Cal Poly, Team 3-24, Regan Fall 2010 Membro di Cal Poly, Team 3-24, Regan Fall 2010
CPSU-REGAN-F10S3G24
4 Membri
12 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 2,992
