Salta al contenuto principale
Audiovox CDM-8900 Main LCD Screen Replacement
Cosa ti serve
  1. Audiovox CDM-8900 Main LCD Screen Replacement, Main LCD Screen: passo 1, immagine 1 di 2 Audiovox CDM-8900 Main LCD Screen Replacement, Main LCD Screen: passo 1, immagine 2 di 2
    • Remove four screw covers using the spudger.
    • Because the bottom two screw covers are attached with an adhesive, you will not be able to replace them when you reassemble the phone.
  2. Audiovox CDM-8900 Main LCD Screen Replacement: passo 2, immagine 1 di 2 Audiovox CDM-8900 Main LCD Screen Replacement: passo 2, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Remove the four Phillips #00 screws.
    • Tweezers may be useful for removing loosened screws.
  3. Audiovox CDM-8900 Main LCD Screen Replacement: passo 3, immagine 1 di 3 Audiovox CDM-8900 Main LCD Screen Replacement: passo 3, immagine 2 di 3 Audiovox CDM-8900 Main LCD Screen Replacement: passo 3, immagine 3 di 3
    • The small electronic components inside the phone are fragile; take care not to damage them when completing this step.
    • Wedge one of the plastic opening tools under the phone cover near the hinge.
    • Insert the second plastic opening tool under the phone cover and slide it around the perimeter.
    • Detach the phone cover from the phone's base.
  4. Audiovox CDM-8900 Main LCD Screen Replacement: passo 4, immagine 1 di 3 Audiovox CDM-8900 Main LCD Screen Replacement: passo 4, immagine 2 di 3 Audiovox CDM-8900 Main LCD Screen Replacement: passo 4, immagine 3 di 3
    • Slide out the two metal braces located along the sides of the LCD screen.
    • Carefully peel back the tape from both sides of the copper frame.
  5. Audiovox CDM-8900 Main LCD Screen Replacement: passo 5, immagine 1 di 2 Audiovox CDM-8900 Main LCD Screen Replacement: passo 5, immagine 2 di 2
    • Do not detach or tear any wires when completing this step.
    • Using the spudger, carefully separate the speaker and microphone from the inside surface of the phone.
    • The smaller black disc is glued down, so you may need to use some force to detach it. Both disks will still remain attached via wires.
  6. Audiovox CDM-8900 Main LCD Screen Replacement: passo 6, immagine 1 di 2 Audiovox CDM-8900 Main LCD Screen Replacement: passo 6, immagine 2 di 2
    • The copper frame is attached to the phone at the hinge. Do not tear the frame.
    • Gently lift the copper frame surrounding the LCD screen.
  7. Audiovox CDM-8900 Main LCD Screen Replacement: passo 7, immagine 1 di 2 Audiovox CDM-8900 Main LCD Screen Replacement: passo 7, immagine 2 di 2
    • With the copper screen lifted up, gently pull out the ribbon connector and lift out the LCD screen.
Conclusione
Aaron Shaw
Membro da: 04/15/10
177 Reputazione
6 Guide realizzate
Cal Poly, Team 28-31, Regan Spring 2010 Membro di Cal Poly, Team 28-31, Regan Spring 2010
CPSU-REGAN-S10S28G31
4 Membri
12 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 45
Tutti i Tempi: 4,338
