Introduzione
This is how to remove the 5 screws and pry the logic board free.
Strumenti
Parti
Nessuna parte specificata.
Hold the phone in one hand, slide the latch up, and pull the battery up to remove it.
Remove the small rubber insert from the top of the phone to access the top screw.
Unscrew all five (5) screws on the back of the cell phone with a Phillips #00 Screwdriver.
If screws do not slide out after unscrewing, gently flip and tap the phone in hand until the screws come loose.
To release the motherboard, push the large "OK" button located on the other side of the phone.
Before reassembly, make sure the keypad is lined up with the motherboard.
Before reassembly, be sure camera lens is properly aligned at the top of the logic board and the volume controls are in place.
