Introduzione
Here is how you replace the logic board from the cell phone.
  1. Hold the phone in one hand, slide latch, and pull to remove the battery.
    • Hold the phone in one hand, slide latch, and pull to remove the battery.
    Aggiungi Commento
  2. Grasp antenna at its base and unscrew.
    • Grasp antenna at its base and unscrew.
    • Remove the antenna along with its plastic casing from inside the battery housing. Keep the antenna in the plastic casing for reassembly.
    Aggiungi Commento
    • Remove small rubber insert from top of phone to access the top screw.
    • Warning: Screws are very small and may be difficult to see while unscrewing.
    • Unscrew all five (5) screws on the back of cell phone.
    • If screws do not remove after fully unthreading, gently invert and tap phone in hand until the screws come loose.
    Aggiungi Commento
    • Wedge back plate away from cell phone using the leverage from the plastic spudger.
    • The volume control button on the left side of the phone will be loose. Make sure to carefully reinsert during reassembly.
    • Detach logic board from LCD screen connector by gently detaching the small copper plate on the top right of the logic board. (shown circled in blue and detached)
    Aggiungi Commento
    • Pop the logic board out from the front of the cell phone.
    • Before reassembly, be sure keypad is lined up with logic board.
    • Before reassembly, be sure camera lens is properly aligned at the top of the logic board and volume controls are in place.
    Aggiungi Commento
    • Grasp camera.
    • Slide camera out of slot from logic board.
    • Camera is difficult to reassemble; there is a white clip for easy camera replacement. Verify that you orient the camera correctly when reinserting.
    Aggiungi Commento
    • Attach camera to new logic board.
    • Follow steps in reverse order to replace logic board.
    Aggiungi Commento
Conclusione
Aaron Shaw
Membro da: 15/04/2010
150 Reputazione
7 Guide realizzate
Cal Poly, Team 28-31, Regan Spring 2010 Membro di Cal Poly, Team 28-31, Regan Spring 2010
CPSU-REGAN-S10S28G31
4 Membri
14 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,574
