Salta al contenuto principale
Audio-Technica LP60XBT Turntable Gear Replacement
Cosa ti serve
  1. Audio-Technica LP60XBT Turntable Gear Replacement, Gear: passo 1, immagine 1 di 2 Audio-Technica LP60XBT Turntable Gear Replacement, Gear: passo 1, immagine 2 di 2
    • Remove the felt pad, and put it to the side.
  2. Audio-Technica LP60XBT Turntable Gear Replacement: passo 2, immagine 1 di 1
    • Turn the platter so that the brass motor pulley can be seen through one of the two outer holes in the platter.
    • If the drive belt is hooked around the motor pulley, unhook it.
    • When reassembling to device, don't forget to hook the new drive belt to the motor pulley.
  3. Audio-Technica LP60XBT Turntable Gear Replacement: passo 3, immagine 1 di 2 Audio-Technica LP60XBT Turntable Gear Replacement: passo 3, immagine 2 di 2
    • Remove the platter by grasping the platter by its two inner holes and lifting it upwards.
    • If the drive belt is unhooked and the tone arm is safely to the side, don’t be afraid to use a small amount of force in lifting the platter if necessary.
  4. Audio-Technica LP60XBT Turntable Gear Replacement: passo 4, immagine 1 di 1
    • Remove the four screws holding in the gears using a Phillips #0 screwdriver.
  5. Audio-Technica LP60XBT Turntable Gear Replacement: passo 5, immagine 1 di 3 Audio-Technica LP60XBT Turntable Gear Replacement: passo 5, immagine 2 di 3 Audio-Technica LP60XBT Turntable Gear Replacement: passo 5, immagine 3 di 3
    • Remove the large white gear by pulling it upwards.
    • Remove the small white gear and base by pulling them upwards.
  6. Audio-Technica LP60XBT Turntable Gear Replacement: passo 6, immagine 1 di 1
    • Insert the small replacement gear first, then the large replacement gear second.
    • When replacing the smaller gear and base, be sure to feed the black ground wire through the hole in the base.
Conclusione
Devon Ferreira
Membro da: 03/22/21
133 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 34
Tutti i Tempi: 1,547
