Salta al contenuto principale
Audio-Technica AT-LP60BK-BT Belt Drive Replacement
Cosa ti serve
  1. Audio-Technica AT-LP60BK-BT Belt Drive Replacement, Belt Drive: passo 1, immagine 1 di 2 Audio-Technica AT-LP60BK-BT Belt Drive Replacement, Belt Drive: passo 1, immagine 2 di 2
    • Open the top plastic cover and remove the record and rubber mat.
  2. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: passo 2, immagine 1 di 2 Audio-Technica AT-LP60BK-BT Belt Drive Replacement: passo 2, immagine 2 di 2
    • Find the belt underneath the platter by rotating the platter to the correct place.
    • Remove the belt from the motor pulley.
  3. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: passo 3, immagine 1 di 1
    • Take the platter off by pulling it straight up.
  4. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: passo 4, immagine 1 di 2 Audio-Technica AT-LP60BK-BT Belt Drive Replacement: passo 4, immagine 2 di 2
    • Remove the old belt.
  5. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: passo 5, immagine 1 di 1
    • Turn platter upside down.
  6. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: passo 6, immagine 1 di 3 Audio-Technica AT-LP60BK-BT Belt Drive Replacement: passo 6, immagine 2 di 3 Audio-Technica AT-LP60BK-BT Belt Drive Replacement: passo 6, immagine 3 di 3
    • Place the new belt around the inner lap on the upside-down platter.
    • Make sure the rubber band is flat on the platter, with no flipping.
  7. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: passo 7, immagine 1 di 1
    • Turn the platter around.
    • Grab the belt around with a finger through one of the holes in the platter.
  8. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: passo 8, immagine 1 di 1
    • Put the platter straight down.
  9. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: passo 9, immagine 1 di 1
    • Put the belt around the motor pulley.
  10. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: passo 10, immagine 1 di 3 Audio-Technica AT-LP60BK-BT Belt Drive Replacement: passo 10, immagine 2 di 3 Audio-Technica AT-LP60BK-BT Belt Drive Replacement: passo 10, immagine 3 di 3
    • Test the function by spinning the platter and put the rubber mat into place.
Conclusione
Un commento
Thank you so much!
Joe - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 30
Ultimi 7 Giorni: 215
Ultimi 30 Giorni: 859
Tutti i Tempi: 10,055
