Salta al contenuto principale
Audio Technica ATH-M50 Ear pads Replacement
  1. Audio Technica ATH-M50 Ear pads Replacement, Preparing Ear pads for removal: passo 1, immagine 1 di 1
    • Unfold the headphones and lay down flat with the pads facing up
    • Once facing up ,tuck your fingers under the edge of the inside of the ear pad and carefully pull up until the ear pad starts to come off
  2. Audio Technica ATH-M50 Ear pads Replacement, Removing the ear pad: passo 2, immagine 1 di 1
    • After creating a gap continue to lift the ear pad off until fully removed
    • For reinstalling the ear pads use the same techniques for a easy installation
    • On older headphones the foam sponge part of the ear pad can deteriorate,it is recommended that if there is any leftover foam that it is remove to the best of your ability to improve the longevity of the headphone,the drivers are delicate please be careful:-)
    • Congratulations you have now removed your M50’s ear pads:-)
Conclusione
Altre 2 persone hanno completato questa guida.
HelloMacOS
Membro da: 01/24/22
26.006 Reputazione
11 Guide realizzate
Repair is War on Entropy Membro di Repair is War on Entropy
Community
25 Membri
1.156 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 36
Tutti i Tempi: 960
