Salta al contenuto principale
Atmega328P Microcontroller Replacement for Arduino Board
Cosa ti serve
  1. Atmega328P Microcontroller Replacement for Arduino Board, Atmega328P Microcontroller: passo 1, immagine 1 di 1
    • Place the Arduino UNO R3 board on a flat clean surface.
    Chiedi a FixBot
    Aggiungi Commento
  2. Atmega328P Microcontroller Replacement for Arduino Board: passo 2, immagine 1 di 2 Atmega328P Microcontroller Replacement for Arduino Board: passo 2, immagine 2 di 2
    • On the right side of board, position a nylon spudger in between the microcontroller and the dip socket, and gently lift upwards to pry it out.
    • The bottom of the microcontroller can be scratched if not done carefully. Do not use a metal tool for this step.
    Chiedi a FixBot
    Aggiungi Commento
  3. Atmega328P Microcontroller Replacement for Arduino Board: passo 3, immagine 1 di 2 Atmega328P Microcontroller Replacement for Arduino Board: passo 3, immagine 2 di 2
    • Repeat the same process on the other side.
    • Lift both sides evenly to prevent any damage to the pins.
    Chiedi a FixBot
    Aggiungi Commento
  4. Atmega328P Microcontroller Replacement for Arduino Board: passo 4, immagine 1 di 3 Atmega328P Microcontroller Replacement for Arduino Board: passo 4, immagine 2 di 3 Atmega328P Microcontroller Replacement for Arduino Board: passo 4, immagine 3 di 3
    • Repeat steps 2 and 3 until the microcontroller is loose enough to remove out of the socket.
    Chiedi a FixBot
    Aggiungi Commento
  5. Atmega328P Microcontroller Replacement for Arduino Board: passo 5, immagine 1 di 1
    • Remove replacement microcontroller out of packaging.
    Chiedi a FixBot
    Aggiungi Commento
  6. Atmega328P Microcontroller Replacement for Arduino Board: passo 6, immagine 1 di 1
    • If needed, straighten the pins of the replacement microcontroller and place it directly over the dip socket.
    • Make sure the notch on the side of the microcontroller is facing the right, matching the white lines on the board.
    Chiedi a FixBot
    Aggiungi Commento
  7. Atmega328P Microcontroller Replacement for Arduino Board: passo 7, immagine 1 di 2 Atmega328P Microcontroller Replacement for Arduino Board: passo 7, immagine 2 di 2
    • Gently press the microcontroller into the dip socket
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
UC Davis, Team 5-5, Morris Winter 2023 Membro di UC Davis, Team 5-5, Morris Winter 2023
UCD-MORRIS-W23S5G5
2 Membri
2 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 14
Ultimi 30 giorni: 57
Tutti i Tempi: 1,438
