Introduzione
Before starting this guide you may need some experience with soldering/ desoldering. If you do not know how, you can learn by clicking the link we put on step 8 (when you have to desolder the backlight).
  1. Before disassembling your Atari Lynx, be sure the device is powered off.
    • Before disassembling your Atari Lynx, be sure the device is powered off.
    • Remove any game in the console by opening the right latch and sliding the game to the right.
  2. Remove the four 35 mm Phillips #1 screws at each corner of the backside on the Atari Lynx.
    • Remove the four 35 mm Phillips #1 screws at each corner of the backside on the Atari Lynx.
    • Pinch the rear panel with your fingers and lift away from the Atari.
  3. Remove the battery panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Remove the battery panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear any wires attached to battery panel.
  4. Kit di riparazione per Android
    Un nuovo schermo o una nuova batteria sono ad un kit di distanza.
    Acquista ora
    Acquista ora
  5. Remove the control panel by pinching the sides with your fingers and lifting  it away from the Atari.
    • Remove the control panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear the speaker wire while removing the control panel.
  6. Pull out the logic-board.
    • Pull out the logic-board.
    • Pull to the sides the four rubber tabs holding in the screen
  7. Unscrew the two 10 mm screws as shown with a Phillips #0 screwdriver in order to remove the shield behind the backlight.
    • Unscrew the two 10 mm screws as shown with a Phillips #0 screwdriver in order to remove the shield behind the backlight.
  8. Flip over the motherboard and remove the shield behind the backlight.
    • Flip over the motherboard and remove the shield behind the backlight.
  9. Flip the motherboard back over and desolder the two components that are holding the backlight in place. If you need help with basic desoldering, click here.
    • Flip the motherboard back over and desolder the two components that are holding the backlight in place.
    • If you need help with basic desoldering, click here.
Conclusione
Altre 3 persone hanno completato questa guida.
John Lopez
Membro da: 27/01/2014
440 Reputation
4 Guide realizzate
Cal Poly, Team 1-42, Maness Winter 2014 Membro di Cal Poly, Team 1-42, Maness Winter 2014
CPSU-MANESS-W14S1G42
5 Membri
13 Guide realizzate
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 27
All Time: 2,648
