Salta al contenuto principale
Atari Flashback 2 Reset and Select Button Replacement
Cosa ti serve
  1. Atari Flashback 2 Reset and Select Button Replacement, Reset or Select Button: passo 1, immagine 1 di 3 Atari Flashback 2 Reset and Select Button Replacement, Reset or Select Button: passo 1, immagine 2 di 3 Atari Flashback 2 Reset and Select Button Replacement, Reset or Select Button: passo 1, immagine 3 di 3
    • Using the screwdriver and the PH1 bit, unscrew the five 10.0 mm screws on the bottom of the console.
    • One screw is under the main sticker in the middle of the console.
  2. Atari Flashback 2 Reset and Select Button Replacement: passo 2, immagine 1 di 3 Atari Flashback 2 Reset and Select Button Replacement: passo 2, immagine 2 di 3 Atari Flashback 2 Reset and Select Button Replacement: passo 2, immagine 3 di 3
    • Unscrew the six 9.0 mm Phillips #1 screws on the brown circuit board that correspond to the reset and select buttons.
    • Remove gently. The circuit board is connected by wire to the console. Removing the cable from the console case may allow more slack.
Conclusione
2Commenti sulla guida
Good night! I have a flashback2 atari which burst the capacitor EC1, could you help me with its value? Thank you!
pradose - Replica
Hi pradose! We no longer have the device so it will not be possible for our team to walk you through anything beyond the guides we posted.
Daniel Hoffman - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 18
Tutti i Tempi: 1,015
