Salta al contenuto principale
Atari Flashback 2 Joystick Button Replacement
Cosa ti serve
  1. Atari Flashback 2 Joystick Button Replacement, Joystick Button: passo 1, immagine 1 di 1
    • Using the screwdriver and the PH1 bit, unscrew the four 10.0 mm screws on the bottom of the joystick.
    • Remove the bottom panel from the joystick.
  2. Atari Flashback 2 Joystick Button Replacement: passo 2, immagine 1 di 1
    • Unscrew the single 8.0 mm Phillips#1 screw holding the circuit board in place.
    • Remove the circuit board from the joystick housing.
  3. Atari Flashback 2 Joystick Button Replacement: passo 3, immagine 1 di 1
    • Inspect the circuit board for dirt, corrosion or damage. If necessary, clean the indicated contact using a cotton swab.
  4. Atari Flashback 2 Joystick Button Replacement: passo 4, immagine 1 di 1
    • Remove the button from the joystick housing. Check for dirt or debris that may obstruct its movement. If the button is broken, replace it.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 402
