Salta al contenuto principale
Atari 5200 Game Cartridge Disassembly
Cosa ti serve
  1. Atari 5200 Game Cartridge Disassembly, Opening up the cartridge: passo 1, immagine 1 di 3 Atari 5200 Game Cartridge Disassembly, Opening up the cartridge: passo 1, immagine 2 di 3 Atari 5200 Game Cartridge Disassembly, Opening up the cartridge: passo 1, immagine 3 di 3
    • Flip the cartridge over.
    • Unscrew the single screw on the back.
    • Carefully pry apart the casing. There are six (6) tabs that need to be released, three (3) each side. If you're not careful they will break. (experience has taught me)
    • Set aside any case parts after dissassembly.
  2. Atari 5200 Game Cartridge Disassembly, Cleaning the Parts: passo 2, immagine 1 di 1
    • Unscrew the board casing, and remove it.
    • Use a compressed air can to blow off any excess dust off the board.
    • Use an alcohol-dabbed cloth to wipe down the gold-plated contacts of the board.
  3. Atari 5200 Game Cartridge Disassembly, Reassembly: passo 3, immagine 1 di 3 Atari 5200 Game Cartridge Disassembly, Reassembly: passo 3, immagine 2 di 3 Atari 5200 Game Cartridge Disassembly, Reassembly: passo 3, immagine 3 di 3
    • Place the two contact protectors together.
    • Place the spring on the knob in the cartridge.
  4. Atari 5200 Game Cartridge Disassembly, Reassembly, Part 2: passo 4, immagine 1 di 3 Atari 5200 Game Cartridge Disassembly, Reassembly, Part 2: passo 4, immagine 2 di 3 Atari 5200 Game Cartridge Disassembly, Reassembly, Part 2: passo 4, immagine 3 di 3
    • Thread the spring into the connected plates.
    • Push the plates into the cartridge against the pressure of the spring.
  5. Atari 5200 Game Cartridge Disassembly, Finishing up: passo 5, immagine 1 di 3 Atari 5200 Game Cartridge Disassembly, Finishing up: passo 5, immagine 2 di 3 Atari 5200 Game Cartridge Disassembly, Finishing up: passo 5, immagine 3 di 3
    • Place the chip in the case.
    • It should "pop" into place.
    • Screw the other side of the case on.
Conclusione
Be sure to test the game, and if freezing still occurs, check the contacts once again.
Altre 3 persone hanno completato questa guida.
USF Tampa, Team 13-1, Staggers Fall 2014 Membro di USF Tampa, Team 13-1, Staggers Fall 2014
USFT-STAGGERS-F14S13G1
5 Membri
17 Guide realizzate
2 Commenti
I’m curious to see the Atari 2600 cartridge inside but I can’t get my hands on one.
The official meme centre. - Replica
it's not a 2600 cart. the systems have similarities, but they are not pin compatible, nor are they software compatible. the 5200 is its own thing.
Gorilla Sapiens - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 41
Tutti i Tempi: 2,882
