Introduzione
In this guide you will learn how to replace the power and volume flex cable in the Asus Zenfone 5.
IMPORTANT NOTE
This guide is for replacing the flex cable instead of the buttons itself, as replacing the buttons is considerably easy I won't make one!
Cosa ti serve
Start by locating the small opener tab at the bottom-left corner of the phone.
Remove the entire back cover.
Remove the following screws:
3 shorter Phillips #00 screws
10 longer Phillips #00 screws
Gently lift the midframe up.
There might be some adhesive beneath these, just keep lifting it up gently.
Identify these:
Flex Cable connector
Power and Volume Button Flex Cable itself
Battery Power connector
Gently pull the Flex Cable connector off from its port.
Take the old Flex Cable off.
Replace the Flex Cable that you've taken off with the new one.
The broken one
The new one
Take the sticker for securing the adhesive off from the new one.
Proceed to the conclusion.
Altre 8 persone hanno completato questa guida.
Un commento
Ahhh! Why Asus mobile phones aren't long lasting. My device is taking long time while charging and it drains too fast. I've also Asus Zenfone max pro m1, and its headphone jack has been stopped to working
