Salta al contenuto principale
Asus Zenfone 4 Max SIM Card Replacement
Cosa ti serve
  1. Asus Zenfone 4 Max SIM Card Replacement, SIM Card: passo 1, immagine 1 di 1
    • Locate the SIM tray on the left edge of the phone.
    • There is a small hole on the outside of the SIM tray that will be used for opening the tray.
  2. Asus Zenfone 4 Max SIM Card Replacement: passo 2, immagine 1 di 2 Asus Zenfone 4 Max SIM Card Replacement: passo 2, immagine 2 di 2
    • Insert a SIM card eject tool into the hole.
    • Press until the SIM tray pops out slightly from the phone.
    • Be careful not to force any object to fit into the tray's opening hole. The object should be thin enough to fit directly into the hole.
  3. Asus Zenfone 4 Max SIM Card Replacement: passo 3, immagine 1 di 2 Asus Zenfone 4 Max SIM Card Replacement: passo 3, immagine 2 di 2
    • Once the SIM tray has been opened, gently pull the tray completely out of the phone.
    • Lift the old SIM card out of the tray with your fingers or flip the tray upside down to make the card fall out.
  4. Asus Zenfone 4 Max SIM Card Replacement: passo 4, immagine 1 di 1
    • Finally, replace the old card with the new SIM card and close the SIM tray.
Conclusione
To reassemble your device, place the SIM tray back into the tray slot
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 36
Tutti i Tempi: 2,170
