Salta al contenuto principale
Asus Zenfone 4 Max Camera Replacement
Cosa ti serve
  1. Asus Zenfone 4 Max Camera Replacement, Camera: passo 1, immagine 1 di 1
    • Using a removable head screwdriver and a T4 bit, remove the screws on the base of the phone on either side of the charging port.
  2. Asus Zenfone 4 Max Camera Replacement: passo 2, immagine 1 di 1
    • Starting near either of the 4 corners of the device notice the seam of the case around the front of the device.
    • Begin using the opening tool with a moderate amount of force to wedge between the back case and the phone.
    • Gently move the tool around the edges towards each corner until the back is removed.
    • You will be able to hear the back casing pulling apart from the phone. Do not be alarmed, but work gently with the device.
  3. Asus Zenfone 4 Max Camera Replacement: passo 3, immagine 1 di 2 Asus Zenfone 4 Max Camera Replacement: passo 3, immagine 2 di 2
    • Using a removable head screwdriver and a PH0 bit, begin removing the panel beneath the two cameras by unscrewing the screw.
  4. Asus Zenfone 4 Max Camera Replacement: passo 4, immagine 1 di 3 Asus Zenfone 4 Max Camera Replacement: passo 4, immagine 2 di 3 Asus Zenfone 4 Max Camera Replacement: passo 4, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use the tweezers to gently pull up on the flaps beneath the two cameras.
    • Completely remove the cameras and replace with the new cameras.
Conclusione
2 Commenti
You can read T3 in the summary and T4 in the instructions: which one do I need?
patriziomaugeri - Replica
Does this fix the Zenfone 4 max camera black screen?
Roger Dufault - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,981
