Salta al contenuto principale
Asus Zenfone 3 Max Screen Replacement
Cosa ti serve
  1. Asus Zenfone 3 Max Screen Replacement, SIM card: passo 1, immagine 1 di 1
    • Locate the SIM card slot on the upper left side of your Asus Zenfone Max 3.
  2. Asus Zenfone 3 Max Screen Replacement: passo 2, immagine 1 di 1
    • Use the iFixit 150mm Flex Extension with the Hex 0.7 bit or the SIM card eject tool.
    • Stick the tool into the hole on the SIM card slot and open the slot with it.
  3. Asus Zenfone 3 Max Screen Replacement: passo 3, immagine 1 di 1
    • Pull out the old SIM card all the way so it is no longer in the phone.
  4. Asus Zenfone 3 Max Screen Replacement, Back cover: passo 4, immagine 1 di 2 Asus Zenfone 3 Max Screen Replacement, Back cover: passo 4, immagine 2 di 2
    • Using an iFixit opening tool, gently wedge the tool between the phone and the back casing.
    • Move the opening tool up and down to pry the back off of the device.
  5. Asus Zenfone 3 Max Screen Replacement: passo 5, immagine 1 di 1
    • Once the original cover has been removed, apply the new cover to the back of the phone with careful pressure.
  6. Asus Zenfone 3 Max Screen Replacement, Battery: passo 6, immagine 1 di 3 Asus Zenfone 3 Max Screen Replacement, Battery: passo 6, immagine 2 di 3 Asus Zenfone 3 Max Screen Replacement, Battery: passo 6, immagine 3 di 3
    • Gently disconnect the gold connection cable indicated by the red circle in the corresponding picture.
    • Pull back on the black adhesive tab that is adhered to the top of the battery. Tab removal is marked in the corresponding picture with a orange circle.
    • Once the gold connection cable and black adhesive tab are no longer connected to the battery, the battery can be removed.
  7. Asus Zenfone 3 Max Screen Replacement: passo 7, immagine 1 di 3 Asus Zenfone 3 Max Screen Replacement: passo 7, immagine 2 di 3 Asus Zenfone 3 Max Screen Replacement: passo 7, immagine 3 di 3
    • Next, remove the battery by gently pulling on the blue removal tab located at the bottom of the device battery.
    • Completely remove existing device battery.
  8. Asus Zenfone 3 Max Screen Replacement, Screen: passo 8, immagine 1 di 3 Asus Zenfone 3 Max Screen Replacement, Screen: passo 8, immagine 2 di 3 Asus Zenfone 3 Max Screen Replacement, Screen: passo 8, immagine 3 di 3
    • Remove the four 2.5mm Phillips #0 screws at the bottom near the speaker and take the small black plastic cover off.
    • Starting at the bottom, disconnect the antenna (long black wire).
    • Disconnect the orange cable.
  9. Asus Zenfone 3 Max Screen Replacement: passo 9, immagine 1 di 2 Asus Zenfone 3 Max Screen Replacement: passo 9, immagine 2 di 2
    • At the top of the phone, disconnect the black screen flex cable (the one that is rectangular) using a black nylon spudger. Peel it all the way back.
    • Using a black nylon spudger, disconnect the charging port flex cable (the other black cable) and microphone button. Peel it all the way back.
    • The metal spudger should not be used on internal components.
  10. Asus Zenfone 3 Max Screen Replacement: passo 10, immagine 1 di 3 Asus Zenfone 3 Max Screen Replacement: passo 10, immagine 2 di 3 Asus Zenfone 3 Max Screen Replacement: passo 10, immagine 3 di 3
    • Remove the four 2.5mm Phillips #0 screws that hold the motherboard and remove the motherboard. Follow our motherboard replacement guide.
    • Remove the (blue) daughterboard. The charging port flex cable will come with it.
    • Be careful when removing the daughterboard. It is thin and adhered very solidly to the screen.
    • Move the rubber piece (denoted with orange circle) from the old port to your new LCD assembly.
Conclusione
Un commento
The indicated part is the battery. I guess that’s an error copied from the Battery Replacement guide. Any recomendations for getting the screen replacement?
cristinalampon - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 24
Tutti i Tempi: 2,828
