Salta al contenuto principale
Asus Zenbook UX32VD RAM Replacement
Cosa ti serve
  1. Asus Zenbook UX32VD RAM Replacement, Bottom Panel: passo 1, immagine 1 di 3 Asus Zenbook UX32VD RAM Replacement, Bottom Panel: passo 1, immagine 2 di 3 Asus Zenbook UX32VD RAM Replacement, Bottom Panel: passo 1, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    T5 Torx Screwdriver
    $9.99
    Compra
  2. Asus Zenbook UX32VD RAM Replacement: passo 2, immagine 1 di 3 Asus Zenbook UX32VD RAM Replacement: passo 2, immagine 2 di 3 Asus Zenbook UX32VD RAM Replacement: passo 2, immagine 3 di 3
    • Use a plastic opening tool to pry along the perimeter of the bottom panel until it can be easily removed.
    • Remove the bottom panel from the body of the laptop.
    • Set aside the bottom panel.
  3. Asus Zenbook UX32VD RAM Replacement, RAM: passo 3, immagine 1 di 3 Asus Zenbook UX32VD RAM Replacement, RAM: passo 3, immagine 2 di 3 Asus Zenbook UX32VD RAM Replacement, RAM: passo 3, immagine 3 di 3
    • Push away the RAM retaining arms from the RAM chip.
    • The RAM chip will spring up once the retaining arms are pushed away from the chip.
    • Remove the RAM chip completely.
Conclusione
Altre 5 persone hanno completato questa guida.
Paola
Membro da: 09/17/15
267 Reputazione
1 Guida realizzata
CSU Fullerton, Team 2-2, Bruce Fall 2015 Membro di CSU Fullerton, Team 2-2, Bruce Fall 2015
CSUF-BRUCE-F15S2G2
4 Membri
6 Guide realizzate
2 Commenti
Replaced the 4 GB RAM module in my UX32VD with an 8 GB Timetec Hynix IC DDR3 1600MHz PC3-12800 Non ECC Unbuffered 1.35V CL11 2Rx8 Dual Rank 204 Pin SODIMM Laptop Notebook Computer Memory Ram Module using this guide. It worked like a charm. Thank you for posting the guide!
Le Zap - Replica
Worked like a charm on a UX32VD. Installed a "Kingston SO-DDR3L-RAM ValueRAM 1600 MHz 1x 8 GB" in 3min
HUGE DIFFERENCE
Thank you very much!
PS. There was a foil wrapper around the old RAM that I removed and put around the new RAM. Heat dissipation I imagine
Valentin - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 19
Tutti i Tempi: 4,588
