Salta al contenuto principale
Asus Zenbook UX32VD Hard Drive Replacement
Cosa ti serve
  1. Asus Zenbook UX32VD Hard Drive Replacement, Bottom Panel: passo 1, immagine 1 di 3 Asus Zenbook UX32VD Hard Drive Replacement, Bottom Panel: passo 1, immagine 2 di 3 Asus Zenbook UX32VD Hard Drive Replacement, Bottom Panel: passo 1, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    T5 Torx Screwdriver
    $9.99
    Compra
  2. Asus Zenbook UX32VD Hard Drive Replacement: passo 2, immagine 1 di 3 Asus Zenbook UX32VD Hard Drive Replacement: passo 2, immagine 2 di 3 Asus Zenbook UX32VD Hard Drive Replacement: passo 2, immagine 3 di 3
    • Use a plastic opening tool to pry along the perimeter of the bottom panel until it can be easily removed.
    • Remove the bottom panel from the body of the laptop.
    • Set aside the bottom panel.
  3. Asus Zenbook UX32VD Hard Drive Replacement, Battery: passo 3, immagine 1 di 2 Asus Zenbook UX32VD Hard Drive Replacement, Battery: passo 3, immagine 2 di 2
    • Remove the eight 3 mm Phillips #0 screws on the bottom panel.
  4. Asus Zenbook UX32VD Hard Drive Replacement: passo 4, immagine 1 di 2 Asus Zenbook UX32VD Hard Drive Replacement: passo 4, immagine 2 di 2
    • Pry up each side of the flat connectors by hand or with a plastic opening tool.
    • Lift the connector straight up from its socket.
  5. Asus Zenbook UX32VD Hard Drive Replacement: passo 5, immagine 1 di 3 Asus Zenbook UX32VD Hard Drive Replacement: passo 5, immagine 2 di 3 Asus Zenbook UX32VD Hard Drive Replacement: passo 5, immagine 3 di 3
    • Unplug the two bundled cable connectors on each side of the battery.
    • Pull the cable away from the connector in the same direction as the individual wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
  6. Asus Zenbook UX32VD Hard Drive Replacement: passo 6, immagine 1 di 1
    • Remove the battery completely.
  7. Asus Zenbook UX32VD Hard Drive Replacement, Hard Drive: passo 7, immagine 1 di 3 Asus Zenbook UX32VD Hard Drive Replacement, Hard Drive: passo 7, immagine 2 di 3 Asus Zenbook UX32VD Hard Drive Replacement, Hard Drive: passo 7, immagine 3 di 3
    Phillips #0 Screwdriver
    $5.49
    Compra
  8. Asus Zenbook UX32VD Hard Drive Replacement: passo 8, immagine 1 di 3 Asus Zenbook UX32VD Hard Drive Replacement: passo 8, immagine 2 di 3 Asus Zenbook UX32VD Hard Drive Replacement: passo 8, immagine 3 di 3
    • Lift the hard drive slightly and gently pull the hard drive from the socket.
    • Do not lift the hard drive too high. Doing so could damage the hard drive or other internal components of the laptop.
    • Remove the hard drive completely.
Conclusione
Altre 12 persone hanno completato questa guida.
CSU Fullerton, Team 2-2, Bruce Fall 2015 Membro di CSU Fullerton, Team 2-2, Bruce Fall 2015
CSUF-BRUCE-F15S2G2
4 Membri
6 Guide realizzate
4 Commenti
Installed a new WD Blue 3D NAND 500GB PC SSD - SATA III 6 Gb/s 2.5"/7mm Solid State Drive into my UX32VD using this guide. It works like charm! Thanks for the guide
Le Zap - Replica
Excellent! Precise and concise to the point!Thank you!
Android Phone - Replica
Exzellent Guide, Thank you so much!
sina - Replica
can someone confirm to me that samsung evo 860 will work or not for this asus please
Karim Othman - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 23
Tutti i Tempi: 10,863
