Salta al contenuto principale
Asus Zenbook UX31E Speaker Replacement
Cosa ti serve
  1. Asus Zenbook UX31E Speaker Replacement, Back Cover: passo 1, immagine 1 di 1
    • Using a T4 Torx screwdriver, remove the ten screws at the marked locations.
    • Place the screws into a container as to not lose them.
  2. Asus Zenbook UX31E Speaker Replacement: passo 2, immagine 1 di 1
    • Carefully slide your iFixit Opening Tool between the back panel.
    • Lift the back plate of your ASUS ZenBook UX31E, and place it to the side.
  3. Asus Zenbook UX31E Speaker Replacement, Speaker: passo 3, immagine 1 di 1
    • Use the plastic opening tool to pry open the back cover of the laptop.
    • Remove the bottom panel of the laptop.
  4. Asus Zenbook UX31E Speaker Replacement: passo 4, immagine 1 di 2 Asus Zenbook UX31E Speaker Replacement: passo 4, immagine 2 di 2
    • Remove the screw connecting the speaker component to the motherboard using the screwdriver.
  5. Asus Zenbook UX31E Speaker Replacement: passo 5, immagine 1 di 2 Asus Zenbook UX31E Speaker Replacement: passo 5, immagine 2 di 2
    • Disconnect the sound cable from the motherboard.
  6. Asus Zenbook UX31E Speaker Replacement: passo 6, immagine 1 di 2 Asus Zenbook UX31E Speaker Replacement: passo 6, immagine 2 di 2
    • Using the plastic opening tool, pry open the speaker component from the computer.
Conclusione
Altre 2 persone hanno completato questa guida.
UW Tacoma, Team 1-2, Rose Winter 2017 Membro di UW Tacoma, Team 1-2, Rose Winter 2017
UWT-ROSE-W17S1G2
4 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 16
Tutti i Tempi: 2,846
