Salta al contenuto principale
Asus Zenbook UX31E Fan Replacement
Cosa ti serve
  1. Asus Zenbook UX31E Fan Replacement, Back Cover: passo 1, immagine 1 di 1
    • Using a T4 Torx screwdriver, remove the ten screws at the marked locations.
    • Place the screws into a container as to not lose them.
  2. Asus Zenbook UX31E Fan Replacement: passo 2, immagine 1 di 1
    • Carefully slide your iFixit Opening Tool between the back panel.
    • Lift the back plate of your ASUS ZenBook UX31E, and place it to the side.
  3. Asus Zenbook UX31E Fan Replacement, Fan: passo 3, immagine 1 di 2 Asus Zenbook UX31E Fan Replacement, Fan: passo 3, immagine 2 di 2
    • Disconnect the ribbon between the IO and the motherboard on both sides.
  4. Asus Zenbook UX31E Fan Replacement: passo 4, immagine 1 di 1
    • Disconnect the fan connector from the motherboard.
    • Pull up the clips on the ribbon connectors.
  5. Asus Zenbook UX31E Fan Replacement: passo 5, immagine 1 di 2 Asus Zenbook UX31E Fan Replacement: passo 5, immagine 2 di 2
    • Unscrew the two screws that are across each other.
  6. Asus Zenbook UX31E Fan Replacement: passo 6, immagine 1 di 2 Asus Zenbook UX31E Fan Replacement: passo 6, immagine 2 di 2
    • Using a plastic opening tool, lift the fan off of the laptop.
    • You can now use your hands and carefully pull the fan off the laptop.
Conclusione
Sinh
Membro da: 02/01/17
101 Reputazione
1 Guida realizzata
UW Tacoma, Team 1-2, Rose Winter 2017 Membro di UW Tacoma, Team 1-2, Rose Winter 2017
UWT-ROSE-W17S1G2
4 Membri
9 Guide realizzate
Un commento
This guide does not explain how to replace the fan, but how to remove the fan.
How do you insert a new fan? (Specifically, how do you remove the fan from the component of which it is a part?)
Thank you in advance.
Albert - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,740
