Salta al contenuto principale
Asus Zenbook UX31A Wi-Fi Card Replacement
Cosa ti serve
  1. Asus Zenbook UX31A Wi-Fi Card Replacement, Wi-Fi Card: passo 1, immagine 1 di 2 Asus Zenbook UX31A Wi-Fi Card Replacement, Wi-Fi Card: passo 1, immagine 2 di 2
    • Use a T6 screwdriver to remove the ten 6 mm case screws.
    • The two screws adjacent to the device serial number stamps are longer than the others. These two screws run about 11 mm long.
  2. Asus Zenbook UX31A Wi-Fi Card Replacement: passo 2, immagine 1 di 2 Asus Zenbook UX31A Wi-Fi Card Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the two 6 mm screws that secure the Wi-Fi card.
    • Wires are loose and easy to disconnect.
  3. Asus Zenbook UX31A Wi-Fi Card Replacement: passo 3, immagine 1 di 1
    • Gently pull the the Wi-Fi card from the motherboard.
    • Disconnect the white and black wire by gently pulling each one up.
    • They can be a little tricky to put back on so take your time and be gentle.
Conclusione
Sherwin
Membro da: 03/22/22
209 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 23
Tutti i Tempi: 339
