Salta al contenuto principale
Asus Zenbook UX31A Battery Replacement
Cosa ti serve
  1. Asus Zenbook UX31A Battery Replacement, Battery: passo 1, immagine 1 di 2 Asus Zenbook UX31A Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Use a T6 screwdriver to remove the ten 6 mm case screws.
    • The two screws adjacent to the device serial number stamps are longer than the others. These two screws run about 11 mm long.
    • Remove the back cover from the laptop.
    • DO NOT BEND OR PUNCTURE THE BATTERY: Puncturing the battery can result in injury since the battery can catch fire or explode when exposed directly to oxygen
  2. Asus Zenbook UX31A Battery Replacement: passo 2, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the three 7 mm screws that secure the battery.
  3. Asus Zenbook UX31A Battery Replacement: passo 3, immagine 1 di 1
    • Unplug the bundled battery connector from the motherboard by gently pulling the cable up.
    • Make sure you pull the connector directly upwards or you could damage the connector
  4. Asus Zenbook UX31A Battery Replacement: passo 4, immagine 1 di 1
    • Remove the battery from the laptop by lifting it up and out.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 33
Tutti i Tempi: 933
