Salta al contenuto principale
Introduzione
If the mouse on your Asus Zenbook UX303L is not moving, moving incorrectly, not clicking, or clicking incorrectly, use this guide to replace its trackpad. Before using this guide, be sure to clean your trackpad of any dirt or debris that might be obstructing the trackpad’s movement and see if that fixes the problem.
The track pad is the small rectangular surface just below the space bar that is used to control the mouse. If available, attach an external USB mouse and verify that the cursor moves and clicks correctly with it. If it does not, the issue may be with the mouse settings.
Before beginning, make sure to power off your Asus Zenbook UX303L completely and disconnect it from any external power source.
  1. Asus Zenbook UX303L Trackpad Replacement, Trackpad: passo 1, immagine 1 di 1
    • Make sure the device is turned off and disconnected from the battery charger.
  2. Asus Zenbook UX303L Trackpad Replacement: passo 2, immagine 1 di 3 Asus Zenbook UX303L Trackpad Replacement: passo 2, immagine 2 di 3 Asus Zenbook UX303L Trackpad Replacement: passo 2, immagine 3 di 3
    • Remove all nine screws from the bottom of the device using a T5 screwdriver.
    • Carefully remove the bottom cover.
    Warning: My UX303L also had two phillips screws under the back two rubber feat. I broke one side trying to get the back panel off.
    Andrew Chan - Replica
  3. Asus Zenbook UX303L Trackpad Replacement: passo 3, immagine 1 di 1
    • Remove five Phillips #1 screws from the battery pack.
  4. Asus Zenbook UX303L Trackpad Replacement: passo 4, immagine 1 di 3 Asus Zenbook UX303L Trackpad Replacement: passo 4, immagine 2 di 3 Asus Zenbook UX303L Trackpad Replacement: passo 4, immagine 3 di 3
    • Unhook the red, black, and white coiled switch.
    • Detach the positive and negative red, black, yellow, and white switch from the motherboard.
    • Unhook the black and white coiled wire from the top of the battery pack.
  5. Asus Zenbook UX303L Trackpad Replacement: passo 5, immagine 1 di 3 Asus Zenbook UX303L Trackpad Replacement: passo 5, immagine 2 di 3 Asus Zenbook UX303L Trackpad Replacement: passo 5, immagine 3 di 3
    • Remove the three screws connecting the SSD to the motherboard.
    • Gently lift and pull out the SSD.
  6. Asus Zenbook UX303L Trackpad Replacement: passo 6, immagine 1 di 3 Asus Zenbook UX303L Trackpad Replacement: passo 6, immagine 2 di 3 Asus Zenbook UX303L Trackpad Replacement: passo 6, immagine 3 di 3
    • Remove the screw attaching the cooling fan to the motherboard.
    • Lift and remove the cooling fan.
  7. Asus Zenbook UX303L Trackpad Replacement: passo 7, immagine 1 di 2 Asus Zenbook UX303L Trackpad Replacement: passo 7, immagine 2 di 2
    • Remove the four Phillips #1 screws attached to the black covered copper bar next to the cooling fan.
    • Gently lift and remove the copper bar.
  8. Asus Zenbook UX303L Trackpad Replacement: passo 8, immagine 1 di 3 Asus Zenbook UX303L Trackpad Replacement: passo 8, immagine 2 di 3 Asus Zenbook UX303L Trackpad Replacement: passo 8, immagine 3 di 3
    • Remove the silver tape to reveal the fourth screw on the motherboard.
    • Detach the motherboard by removing the four Phillips #1 screws.
    • Detach the white wire connecting the motherboard by lifting the black flap and pulling it out.
  9. Asus Zenbook UX303L Trackpad Replacement: passo 9, immagine 1 di 1
    • By using ESD-safe tweezers, remove the gray colored wire.
    • Remove the white wire using tweezers.
    • Remove the blue colored wire by lifting the black flap and pulling the blue flap out.
  10. Asus Zenbook UX303L Trackpad Replacement: passo 10, immagine 1 di 3 Asus Zenbook UX303L Trackpad Replacement: passo 10, immagine 2 di 3 Asus Zenbook UX303L Trackpad Replacement: passo 10, immagine 3 di 3
    • Remove the white wire with the blue ends by lifting the black flap with tweezers and gently pulling out.
    • Gently remove the silver tape using tweezers.
    • Remove the Phillips #1 screws.
  11. Asus Zenbook UX303L Trackpad Replacement: passo 11, immagine 1 di 2 Asus Zenbook UX303L Trackpad Replacement: passo 11, immagine 2 di 2
    • Place the plastic opening tools under the trackpad.
    • Gently pull out and remove the trackpad.
Conclusione
Altre 3 persone hanno completato questa guida.
Fredis Benitez
Membro da: 13/10/2015
259 Reputazione
1 Guida realizzata
Un commento
This laptop comes with a very bad trackpad, it has very low resolution. Do you think it can be updated?
eduugr - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 28
Tutti i Tempi: 5,197
