Salta al contenuto principale
Asus Zenbook UX303L Speaker Replacement
Cosa ti serve
  1. Asus Zenbook UX303L Speaker Replacement, Speaker: passo 1, immagine 1 di 1
    • Remove the eight 3mm screws using the T5 Torx Screwdriver.
    • Remove the 8mm screw using the T5 Torx Screwdriver.
  2. Asus Zenbook UX303L Speaker Replacement: passo 2, immagine 1 di 1
    • Carefully remove the back plate from the laptop and located the battery and speakers towards the top.
  3. Asus Zenbook UX303L Speaker Replacement: passo 3, immagine 1 di 1
    • Remove the four 4mm screws using the Phillips #0 screwdriver.
    • Remove the single 6mm screw using the Phillips #0 screwdriver.
  4. Asus Zenbook UX303L Speaker Replacement: passo 4, immagine 1 di 1
    • Using your finger, gently lift upwards to remove the connection clip from the motherboard.
  5. Asus Zenbook UX303L Speaker Replacement: passo 5, immagine 1 di 1
    • Gently pull the speaker connection clip outwards to remove it.
  6. Asus Zenbook UX303L Speaker Replacement: passo 6, immagine 1 di 1
    • Carefully remove the speaker wires that are tucked underneath the tabs located at the edge of the laptop case.
    • Gently remove the battery from the laptop, the defective speakers should be glued with adhesive to the battery.
  7. Asus Zenbook UX303L Speaker Replacement: passo 7, immagine 1 di 1
    • Carefully peel away the defective speakers from the battery.
Conclusione
Ryan Snow
Membro da: 04/01/19
202 Reputazione
1 Guida realizzata
IUPUI, Team S1-G6, Harley Spring 2019 Membro di IUPUI, Team S1-G6, Harley Spring 2019
IUPUI-HARLEY-S19S1G6
3 Membri
7 Guide realizzate
Un commento
Is the Asus UX303L same as U303L?
Michael Wolf - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 29
Tutti i Tempi: 1,795
