Salta al contenuto principale
Asus Zenbook UX303L Cooling Fan Replacement
Cosa ti serve
  1. Asus Zenbook UX303L Cooling Fan Replacement, Cooling Fan: passo 1, immagine 1 di 1
    • Make sure the device is turned off and disconnected from the battery charger.
  2. Asus Zenbook UX303L Cooling Fan Replacement: passo 2, immagine 1 di 3 Asus Zenbook UX303L Cooling Fan Replacement: passo 2, immagine 2 di 3 Asus Zenbook UX303L Cooling Fan Replacement: passo 2, immagine 3 di 3
    • Remove the rubber pads closer to the air vents and remove the two screws using a P0 screwdriver.
    • Remove all the nine screws from the bottom of the device using a T5 screwdriver.
    • Carefully remove the bottom cover.
  3. Asus Zenbook UX303L Cooling Fan Replacement: passo 3, immagine 1 di 2 Asus Zenbook UX303L Cooling Fan Replacement: passo 3, immagine 2 di 2
    • Pull on the black flap to lift the LVDS cable next to the cooling fan.
  4. Asus Zenbook UX303L Cooling Fan Replacement: passo 4, immagine 1 di 3 Asus Zenbook UX303L Cooling Fan Replacement: passo 4, immagine 2 di 3 Asus Zenbook UX303L Cooling Fan Replacement: passo 4, immagine 3 di 3
    • Remove the three screws from the hinges using a PH-1 screwdriver.
    • Open the device at a 90 degree angle to free the hinges.
  5. Asus Zenbook UX303L Cooling Fan Replacement: passo 5, immagine 1 di 3 Asus Zenbook UX303L Cooling Fan Replacement: passo 5, immagine 2 di 3 Asus Zenbook UX303L Cooling Fan Replacement: passo 5, immagine 3 di 3
    • Remove the screws attached to the cooling fan with a PH-1 screwdriver.
    • Disconnect the wire attaching the cooling fan to the motherboard.
  6. Asus Zenbook UX303L Cooling Fan Replacement: passo 6, immagine 1 di 2 Asus Zenbook UX303L Cooling Fan Replacement: passo 6, immagine 2 di 2
    • Gently lift and slide the cooling fan out.
Conclusione
Altre 4 persone hanno completato questa guida.
3 Commenti
After the 6 step Would i then just remove the dust on the cooling fan and reassemble after that? or replace the fan as a whole
Sean Gerald Wong - Replica
I wish you guys had included the part number for the cooling fan.
mhyson - Replica
I think that it is important to recommend to remove the battery first, otherwise there is a risk of short...
Don't ask me how I know... :-(
Nmariotti - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 30
Tutti i Tempi: 6,159
