Salta al contenuto principale
Asus Zenbook UM325U
Cosa ti serve
  1. Asus Zenbook UM325U, Find all the screws and open the bottom: passo 1, immagine 1 di 1
    • Be aware: 2 Torx are hidden under the back 2 feet of the laptop!
  2. Asus Zenbook UM325U, Pull the back with a spudger: passo 2, immagine 1 di 2 Asus Zenbook UM325U, Pull the back with a spudger: passo 2, immagine 2 di 2
    • This is the inside of the backplate: see all the small lips that attach to click the backplate to the chassis.
    • Use a spudger to open this up, starting from the front (the user-side) to the back (where the monitor attaches)
  3. Asus Zenbook UM325U, Replacing the SSD, Battery or go for further disassembly: passo 3, immagine 1 di 3 Asus Zenbook UM325U, Replacing the SSD, Battery or go for further disassembly: passo 3, immagine 2 di 3 Asus Zenbook UM325U, Replacing the SSD, Battery or go for further disassembly: passo 3, immagine 3 di 3
    • Now that the chassis is opened, you can: 1) replace the ssd 2) replace the battery 3) continue onwards and dissasemble it further
    • Please do not forget to disconnect the battery cable when disassembling further!
Conclusione
hjheins
Membro da: 01/28/15
259 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 56
Tutti i Tempi: 817
