Salta al contenuto principale
Asus ZenWatch 2 Motherboard Replacement
Cosa ti serve
  1. Asus ZenWatch 2 Motherboard Replacement, Motherboard: passo 1, immagine 1 di 1
    • Remove the four 3.5mm screws using a T5 screwdriver to open the faceplate.
  2. Asus ZenWatch 2 Motherboard Replacement: passo 2, immagine 1 di 2 Asus ZenWatch 2 Motherboard Replacement: passo 2, immagine 2 di 2
    • Remove the two 1.8mm silver screws using the PH00 screwdriver.
  3. Asus ZenWatch 2 Motherboard Replacement: passo 3, immagine 1 di 2 Asus ZenWatch 2 Motherboard Replacement: passo 3, immagine 2 di 2
    • Slide the spudger under the gold-plated connection ribbon and lift to disconnect from the motherboard.
  4. Asus ZenWatch 2 Motherboard Replacement: passo 4, immagine 1 di 2 Asus ZenWatch 2 Motherboard Replacement: passo 4, immagine 2 di 2
    • Pull up on the motherboard using tweezers to detach it from the watch.
Conclusione
Andrew
Membro da: 02/20/17
314 Reputazione
2 Guide realizzate
USF Tampa, Team S1-G1, Leahy Spring 2017 Membro di USF Tampa, Team S1-G1, Leahy Spring 2017
USFT-LEAHY-S17S1G1
3 Membri
10 Guide realizzate
6 Commenti
Step 3 requires three different connectors to be removed from the mainboard. Not one. Attempting to remove the mainboard after only disconnecting the gold-plated connector can result in damaged digitizer/display cable.
s3ae - Replica
Out of curiosity, I don’t see the battery hiding in any of the pictures. Is it glued or otherwise attached to the backplate of the watch, and since you’re focused on the mainboard, we’re not seeing it for that reason? Thanks!
MD5Hash - Replica
Battery is actually stuck to the bottom side of the case. It looks to be pretty easy to replace. Connection is done with 4 sets of pins (at least 2 for battery)
Jean-Guy Rivard -
Where can you purchase a replacement motherboard?
Tasha Kanahele - Replica
My zenfone wach 2 all function not showing please help me
Akhtar - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 16
Tutti i Tempi: 2,593
