Introduzione
This is a guide on how to replace the motherboard of an Asus ZenFone 5. The tools needed are a Spudger, a Halberd Spudger, an iOpener, iFixit Opening Picks, iFixit Opening Tool, and a Phillips #00 Screwdriver. There are many parts at risk of being damaged, ensure that you follow the procedure with care. The time needed to complete this procedure is approximately forty-five to fifty-five minutes.
Cosa ti serve
Insert a SIM card removal tool or the end of a paperclip into the small hole on the lefthand side of the phone to release the SIM card.
Pull out the SIM card tray.
Use a halberd spudger to pry up the battery's press fit connector from the motherboard.
Gently pry the battery out of the case, taking care not to bend or puncture the battery.
Gently use a spudger to remove the wired connections on the motherboard.
Disconnect both ribbon cables by popping up the locking tab of the zif connectors and pulling the cable out.
Pry up the black coaxial cable and it will pop off its connector on the motherboard.
Remove the two screws holding down the motherboard with a Phillips #00 screwdriver.
Altre 2 persone hanno completato questa guida.
