Introduzione
The MicroSD card is one of the most common replacements for the ZenFone 5, and luckily, one of the easiest. The only tool required is a pin to fit in a small hole on the phone. If you do not have an advanced toolkit, some common household objects can also work, such as a thumbtack, needle, etc.
Cosa ti serve
If you have a case, remove it so you can see the sides of the phone.
The slot for the MicroSD card, with the screen facing up, is on the left edge with a small hole.
