Introduzione
Follow this guide if you need to replace the battery of your Asus ZenFone 5.
The battery is one of the most important parts of the phone and often needs replacement. A battery that needs to be replaced will often lose charging ability and charge retention, and the phone will often overheat if the battery is worn out.
This guide shows the use of metal tools in close vicinity to the battery. Choose to use plastic, ESD-safe tools for the opening procedure in order to greatly reduce the risk of a battery puncture.
Strumenti
Parti
Nessuna parte specificata.
To put the battery back in, replace the orange tab on the top of the battery on its socket.
