Introduzione
Use this guide to replace the display in your Asus ZenFone 2 Laser 5" Model ZE550KL
Cosa ti serve
Remove the back cover.
Disconnect the battery.
Remove the SIM card and the micro SD card.
Remove the plastic back with opening picks making sure not to break the clips that hold it in place
Disconnect the two flat cables by lifting the white bracket
Unplug the camera
With the help of a hair dryer, heat gun or an iOpener remove the screen from the phone's frame
Remove glue residues on the perimeter of the frame
Re-adhere the display
Replace or reposition the dust gasket of the front camera before installing the new screen
Insert the new screen into position by passing the flat into the specific grooves
Altre 3 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
Un commento
Just had my cracked LCD replaced. Everything was working fine before the replacement but after that, a third of a centimeter and all the subkeys (Back, Home, Recent keys) we rented working. The tech tried to checkout the fitting but it still didn't work. Had to install an assistive key app to be able to use the phone. He told me to go back on Thursday to replace the LCD with a different one cuz this last unit they had might be defective. Could it be a screen seating problem or an issue related to glue remnants or excess adhesive?
