Salta al contenuto principale
Asus ZenBook Flip UX360C Solid State Drive Replacement
Cosa ti serve
  1. Asus ZenBook Flip UX360C Solid State Drive Replacement, Solid State Drive: passo 1, immagine 1 di 1
    • Attach an ESD wristband to your wrist and clip the grounding clamp to a grounded metal object.
  2. Asus ZenBook Flip UX360C Solid State Drive Replacement: passo 2, immagine 1 di 1
    • Remove all eleven 5 mm Phillips #1 screws on the back cover.
  3. Asus ZenBook Flip UX360C Solid State Drive Replacement: passo 3, immagine 1 di 1
    • Use plastic opening tools to remove the keyboard panel.
  4. Asus ZenBook Flip UX360C Solid State Drive Replacement: passo 4, immagine 1 di 1
    • Use a plastic opening tool to disconnect the ZIF keyboard ribbon cable from the motherboard.
  5. Asus ZenBook Flip UX360C Solid State Drive Replacement: passo 5, immagine 1 di 1
    • Unscrew the 5 mm Phillips #1 retaining screw holding the SSD in place.
    • Carefully remove the SSD.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 59
Tutti i Tempi: 3,227
