Salta al contenuto principale
Asus Zen AiO Pro Z240IC Screen Replacement
Cosa ti serve
  1. Asus Zen AiO Pro Z240IC Screen Replacement, Screen: passo 1, immagine 1 di 2 Asus Zen AiO Pro Z240IC Screen Replacement, Screen: passo 1, immagine 2 di 2
    • Use the plastic opening tool to pry off the black plastic strip at the bottom of the screen by wiggling the tool between the strip and the screen.
    • The strip is held in place with adhesive. You may hear a crackling sound as the strip is peeled off.
    • Run the opening tool slowly along the base of the screen, peeling the black strip back, until the opposite end of the screen is reached.
    On my machine, it was positively impossible to use a plastic opening tool, or even a razor to get under the plastic strip - even after heating up with a heat gun. However, I found another method that will also help prevent damage to the plastic strip: in pictures for Steps 2 and 3, you can see that under the plastic strip, next to some of the screws there are square holes in the plastic body. I was able to shape a sturdy paper clip into an “L” shape, and feed it through the right-most exhaust vent at the bottom to insert into this square hole from below. From there, you can use the paper clip to try to push the plastic strip up from below. It still required some heat from the heat gun, but eventually I was able to push the plastic strip up enough to be able to slip a razor blade under it.
    Alexander V Trofimuk - Replica
    I too was unable to do this with the plastic tools, but used a small flat screwdriver to ply up the corned on the bottom curved corner and plastic tools form there - just left a small blemish on the plastic besel, but I can live with that.
    Andy Monaghan - Replica
  2. Asus Zen AiO Pro Z240IC Screen Replacement: passo 2, immagine 1 di 2 Asus Zen AiO Pro Z240IC Screen Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #1 screwdriver to remove the seven (7) 4.8 mm screws from the base of the screen.
  3. Asus Zen AiO Pro Z240IC Screen Replacement: passo 3, immagine 1 di 3 Asus Zen AiO Pro Z240IC Screen Replacement: passo 3, immagine 2 di 3 Asus Zen AiO Pro Z240IC Screen Replacement: passo 3, immagine 3 di 3
    • Place the computer on its back, facing up.
    • Wedge the plastic opening tool in between the screen and the bezel of the aluminum computer casing.
    • Move the tool along the entire edge of the screen with an up-and-down prying motion to loosen the screen from the casing. Do not lift the entire screen away from the computer yet.
    • The screen is held in place by plastic tabs. These will create a popping sound when loosened.
    • The screen assembly will flex as it is pried off. Do not bend the screen too far or the glass screen could shatter.
    It’s a lot easier to use two suction cups on the bottom corners, and then slide some cards in between the screen and the case.
    Alec - Replica
  4. Asus Zen AiO Pro Z240IC Screen Replacement: passo 4, immagine 1 di 1
    • Lift the screen from the bottom edge by about 6 inches. Prop it open with one hand.
    • Look inside the computer and locate five (5) cables that connect the embedded components of the screen (camera, microphone, etc.) to the rest of the computer.
    I have this model, but I only found 4 cables, 2 were ribbon cables. Just look inside and unplug anything that is connecting the display to the motherboard.
    Alec - Replica
    Same here my model just had 4 cables.
  5. Asus Zen AiO Pro Z240IC Screen Replacement: passo 5, immagine 1 di 3 Asus Zen AiO Pro Z240IC Screen Replacement: passo 5, immagine 2 di 3 Asus Zen AiO Pro Z240IC Screen Replacement: passo 5, immagine 3 di 3
    • Remove the two (2) cables that are connected to the computer by white, rectangular terminal blocks by pulling straight out on the plug.
    • The cables and wires in these steps are delicate; do not tug on the individual wires that make up each cable.
  6. Asus Zen AiO Pro Z240IC Screen Replacement: passo 6, immagine 1 di 3 Asus Zen AiO Pro Z240IC Screen Replacement: passo 6, immagine 2 di 3 Asus Zen AiO Pro Z240IC Screen Replacement: passo 6, immagine 3 di 3
    • Use a finger to lift the plastic locking flaps that hold the remaining three (3) ribbon cables in place.
    • Remove the cables from their terminals by slipping them away from their connectors.
    • The black line on the ribbon cables mark the connecting region. When reinstalling, insert the cable up to this line so the locking flap covers it.
    When re-connecting take great care to ensure the ribbon cables are square and flat - I had to take mine apart again to re-seat one as the screen was blank - worked fine once re-seated properly.
Conclusione
Cal Poly, Team S4-G1, Livingston Fall 2017 Membro di Cal Poly, Team S4-G1, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G1
5 Membri
25 Guide realizzate
2 Commenti
Can anyone tell me where I can find this display / lcd for sale?
Thanks
apds - Replica
In step 6 you are removing a ribbon cable with your fingernail. The same cable is damaged for me. Can you share the part number of this cable? I can see this a label is on this cable. I believe this is enabling the digitiser to work. I contacted Asus UK and they have no clue. Thanks
Paul Kormany - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 43
Tutti i Tempi: 5,830
