Salta al contenuto principale
Asus Zen AiO Pro Z240IC Hard Drive Replacement
Cosa ti serve
  1. Asus Zen AiO Pro Z240IC Hard Drive Replacement, Screen: passo 1, immagine 1 di 2 Asus Zen AiO Pro Z240IC Hard Drive Replacement, Screen: passo 1, immagine 2 di 2
    • Use the plastic opening tool to pry off the black plastic strip at the bottom of the screen by wiggling the tool between the strip and the screen.
    • The strip is held in place with adhesive. You may hear a crackling sound as the strip is peeled off.
    • Run the opening tool slowly along the base of the screen, peeling the black strip back, until the opposite end of the screen is reached.
  2. Asus Zen AiO Pro Z240IC Hard Drive Replacement: passo 2, immagine 1 di 2 Asus Zen AiO Pro Z240IC Hard Drive Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #1 screwdriver to remove the seven (7) 4.8 mm screws from the base of the screen.
  3. Asus Zen AiO Pro Z240IC Hard Drive Replacement: passo 3, immagine 1 di 3 Asus Zen AiO Pro Z240IC Hard Drive Replacement: passo 3, immagine 2 di 3 Asus Zen AiO Pro Z240IC Hard Drive Replacement: passo 3, immagine 3 di 3
    • Place the computer on its back, facing up.
    • Wedge the plastic opening tool in between the screen and the bezel of the aluminum computer casing.
    • Move the tool along the entire edge of the screen with an up-and-down prying motion to loosen the screen from the casing. Do not lift the entire screen away from the computer yet.
    • The screen is held in place by plastic tabs. These will create a popping sound when loosened.
    • The screen assembly will flex as it is pried off. Do not bend the screen too far or the glass screen could shatter.
  4. Asus Zen AiO Pro Z240IC Hard Drive Replacement: passo 4, immagine 1 di 1
    • Lift the screen from the bottom edge by about 6 inches. Prop it open with one hand.
    • Look inside the computer and locate five (5) cables that connect the embedded components of the screen (camera, microphone, etc.) to the rest of the computer.
  5. Asus Zen AiO Pro Z240IC Hard Drive Replacement: passo 5, immagine 1 di 3 Asus Zen AiO Pro Z240IC Hard Drive Replacement: passo 5, immagine 2 di 3 Asus Zen AiO Pro Z240IC Hard Drive Replacement: passo 5, immagine 3 di 3
    • Remove the two (2) cables that are connected to the computer by white, rectangular terminal blocks by pulling straight out on the plug.
    • The cables and wires in these steps are delicate; do not tug on the individual wires that make up each cable.
  6. Asus Zen AiO Pro Z240IC Hard Drive Replacement: passo 6, immagine 1 di 3 Asus Zen AiO Pro Z240IC Hard Drive Replacement: passo 6, immagine 2 di 3 Asus Zen AiO Pro Z240IC Hard Drive Replacement: passo 6, immagine 3 di 3
    • Use a finger to lift the plastic locking flaps that hold the remaining three (3) ribbon cables in place.
    • Remove the cables from their terminals by slipping them away from their connectors.
    • The black line on the ribbon cables mark the connecting region. When reinstalling, insert the cable up to this line so the locking flap covers it.
  7. Asus Zen AiO Pro Z240IC Hard Drive Replacement, Hard Drive: passo 7, immagine 1 di 3 Asus Zen AiO Pro Z240IC Hard Drive Replacement, Hard Drive: passo 7, immagine 2 di 3 Asus Zen AiO Pro Z240IC Hard Drive Replacement, Hard Drive: passo 7, immagine 3 di 3
    • Use a Phillips #0 to remove the four (4) 3.2 mm screws on the metal casing enclosing the hard drive.
    • Remove the metal casing by lifting it up.
  8. Asus Zen AiO Pro Z240IC Hard Drive Replacement: passo 8, immagine 1 di 3 Asus Zen AiO Pro Z240IC Hard Drive Replacement: passo 8, immagine 2 di 3 Asus Zen AiO Pro Z240IC Hard Drive Replacement: passo 8, immagine 3 di 3
    • Remove the SATA cable by pushing down on the metal tab and pulling the cable away from the drive.
    • Remove the power cable by pinching the black connector and pulling the cable out.
    • Take out the drive by lifting it out of its rubber seat.
Conclusione
Altre 17 persone hanno completato questa guida.
Cal Poly, Team S4-G1, Livingston Fall 2017 Membro di Cal Poly, Team S4-G1, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G1
5 Membri
25 Guide realizzate
18 Commenti
Does the black strip help in place with adhesive go back on easily or do you need to use new tape to help back in place?
wdkunkel - Replica
Pas de souci pour remettre la bande adhésive, elle reste collante.
Alain Benhaim -
I have reused adhesive strip without any special
Marcin Pietrusewicz -
After step 5 its possible to raise screen and unscrew hard
Marcin Pietrusewicz - Replica
dose it has space for 2 hdd or only one
alexandru mihalachi - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 29
Ultimi 30 Giorni: 103
Tutti i Tempi: 18,402
