Salta al contenuto principale
Asus Z54C-JS31 WiFi Card Replacement
Cosa ti serve
  1. Asus Z54C-JS31 WiFi Card Replacement, Battery: passo 1, immagine 1 di 3 Asus Z54C-JS31 WiFi Card Replacement, Battery: passo 1, immagine 2 di 3 Asus Z54C-JS31 WiFi Card Replacement, Battery: passo 1, immagine 3 di 3
    • Turn the laptop upside down so that the underside is facing up and locate the two switches that are on each side of the battery.
    • Slide the switch on the top right corner to the right.
    • Slide and hold the switch on the top left corner to the left and carefully remove the battery.
  2. Asus Z54C-JS31 WiFi Card Replacement, HDD/RAM Cover Panel: passo 2, immagine 1 di 2 Asus Z54C-JS31 WiFi Card Replacement, HDD/RAM Cover Panel: passo 2, immagine 2 di 2
    • Use a Phillips #000 screwdriver to remove the two 9mm screws from the HDD/RAM cover panel.
  3. Asus Z54C-JS31 WiFi Card Replacement: passo 3, immagine 1 di 2 Asus Z54C-JS31 WiFi Card Replacement: passo 3, immagine 2 di 2
    • Slide the back panel off by placing a hand on each corner and pulling the panel towards you.
  4. Asus Z54C-JS31 WiFi Card Replacement, WiFi Card: passo 4, immagine 1 di 3 Asus Z54C-JS31 WiFi Card Replacement, WiFi Card: passo 4, immagine 2 di 3 Asus Z54C-JS31 WiFi Card Replacement, WiFi Card: passo 4, immagine 3 di 3
    • Disconnect both the black and white coaxial connectors from the WiFi card by pulling up on the gold colored piece.
  5. Asus Z54C-JS31 WiFi Card Replacement: passo 5, immagine 1 di 3 Asus Z54C-JS31 WiFi Card Replacement: passo 5, immagine 2 di 3 Asus Z54C-JS31 WiFi Card Replacement: passo 5, immagine 3 di 3
    • Remove the 3mm screw from the top right corner of the WiFi card using a Phillips #0 screwdriver.
    • The WiFi card will pop up. Grasp it and pull it out of its slot.
Conclusione
Mark DeSimone
Membro da: 10/19/17
801 Reputazione
8 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,672
