Introduzione
The motherboard connects all the hardware components of the laptop so that they can communicate with each other.
Cosa ti serve
Turn the laptop upside down so that the underside is facing up and locate the two switches that are on each side of the battery.
Slide the switch on the top right corner to the right.
Slide and hold the switch on the top left corner to the left and carefully remove the battery.
Use a Phillips #000 screwdriver to remove the two 9mm screws from the HDD/RAM cover panel.
Disconnect both the black and white coaxial connectors from the WiFi card by pulling up on the gold colored piece.
Turn the laptop to its normal position and open the display to show the keyboard.
Gently push back the five tabs holding the keyboard down using the plastic opening tool.
Remove the 3mm screw with a Phillips #000 screwdriver.
Slide out the optical disc drive by pulling it away from the laptop.
Turn the laptop over so that the back side is facing up.
Remove eight 9mm screws from the back of the laptop.
Remove two 6mm screws near the battery.
Remove two 3mm screws from the optical drive slot.
