Salta al contenuto principale
Asus X751L DVD Drive Replacement
Cosa ti serve
  1. Asus X751L DVD Drive Replacement, Keyboard: passo 1, immagine 1 di 1
    • With the screen closed, place your laptop upside-down with the front facing you.
    • Remove the six 14.6mm Phillips #00 screws.
    • Remove the four 6.6mm Phillips #00 screws.
  2. Asus X751L DVD Drive Replacement: passo 2, immagine 1 di 1
    • Flip the laptop over and open the lid.
    • Pry around the edges of the laptop base using the plastic opening tool.
    • Prying too hard can break the plastic clips.
  3. Asus X751L DVD Drive Replacement: passo 3, immagine 1 di 3 Asus X751L DVD Drive Replacement: passo 3, immagine 2 di 3 Asus X751L DVD Drive Replacement: passo 3, immagine 3 di 3
    • Carefully lift the keyboard up.
    • Be very careful when lifting the keyboard up. Two zero insertion force (ZIF) cables are between the keyboard assembly and the motherboard. Do not lift the assembly too high.
    • Disconnect the two ZIF connectors from the motherboard using your fingernail to lift the cream-colored tab.
  4. Asus X751L DVD Drive Replacement, DVD Drive: passo 4, immagine 1 di 1
    • With the keyboard panel open, face the laptop with the internal components facing towards you.
    • Remove the single 4.6mm Phillips #00 screw.
  5. Asus X751L DVD Drive Replacement: passo 5, immagine 1 di 1
    • Pull the optical drive out.
Conclusione
Altre 2 persone hanno completato questa guida.
Carl Ravina
Membro da: 02/02/17
125 Reputazione
1 Guida realizzata
USF Tampa, Team 17-2, Blackwell Spring 2017 Membro di USF Tampa, Team 17-2, Blackwell Spring 2017
USFT-BLACKWELL-S17S17G2
4 Membri
5 Guide realizzate
Un commento
Spot on, took away any worries…………
paul pepper - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 2,308
