Salta al contenuto principale
Asus X751L Battery Replacement
Cosa ti serve
  1. Asus X751L Battery Replacement, Keyboard: passo 1, immagine 1 di 1
    • With the screen closed, place your laptop upside-down with the front facing you.
    • Remove the six 14.6mm Phillips #00 screws.
    • Remove the four 6.6mm Phillips #00 screws.
  2. Asus X751L Battery Replacement: passo 2, immagine 1 di 1
    • Flip the laptop over and open the lid.
    • Pry around the edges of the laptop base using the plastic opening tool.
    • Prying too hard can break the plastic clips.
  3. Asus X751L Battery Replacement: passo 3, immagine 1 di 3 Asus X751L Battery Replacement: passo 3, immagine 2 di 3 Asus X751L Battery Replacement: passo 3, immagine 3 di 3
    • Carefully lift the keyboard up.
    • Be very careful when lifting the keyboard up. Two zero insertion force (ZIF) cables are between the keyboard assembly and the motherboard. Do not lift the assembly too high.
    • Disconnect the two ZIF connectors from the motherboard using your fingernail to lift the cream-colored tab.
  4. Asus X751L Battery Replacement, Battery: passo 4, immagine 1 di 1
    • Remove the two 6.6mm Phillips #00 screws holding the battery in place.
  5. Asus X751L Battery Replacement: passo 5, immagine 1 di 2 Asus X751L Battery Replacement: passo 5, immagine 2 di 2
    • Lift the battery from the cable-side to maneuver it around the plastic clips.
  6. Asus X751L Battery Replacement: passo 6, immagine 1 di 3 Asus X751L Battery Replacement: passo 6, immagine 2 di 3 Asus X751L Battery Replacement: passo 6, immagine 3 di 3
    • Using your finger nails, gently push the battery cable out of the connector on the motherboard.
    • Once the cable is disconnected, you can remove the battery.
Conclusione
Altre 4 persone hanno completato questa guida.
USF Tampa, Team 17-2, Blackwell Spring 2017 Membro di USF Tampa, Team 17-2, Blackwell Spring 2017
USFT-BLACKWELL-S17S17G2
4 Membri
5 Guide realizzate
6 Commenti
Very nice, thank you !
anh
barzamjavel - Replica
very nice, thank you !
Anh
Took me awhile to figure out how to get the cables back. Other than that, good insturctions.
Jacqueline Foxall - Replica
Your instructions were easy to follow. Thank you!!!
theresa collet - Replica
very helpful
khan - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 48
Tutti i Tempi: 12,868
