Salta al contenuto principale
Asus X55C HDD (Hard Disk Drive) Replacement
Cosa ti serve
Panoramica Video
  1. Asus X55C HDD (Hard Disk Drive) Replacement, HDD (Hard Disk Drive): passo 1, immagine 1 di 3 Asus X55C HDD (Hard Disk Drive) Replacement, HDD (Hard Disk Drive): passo 1, immagine 2 di 3 Asus X55C HDD (Hard Disk Drive) Replacement, HDD (Hard Disk Drive): passo 1, immagine 3 di 3
    • Switch off the Laptop and remove the Battery.
    • Unscrew the two Philips screws and remove the HDD / RAM Cover.
  2. Asus X55C HDD (Hard Disk Drive) Replacement: passo 2, immagine 1 di 3 Asus X55C HDD (Hard Disk Drive) Replacement: passo 2, immagine 2 di 3 Asus X55C HDD (Hard Disk Drive) Replacement: passo 2, immagine 3 di 3
    • Remove three screws securing the hard drive caddy (hard drive assembly).
    • Slide the hard drive assembly to the left to disconnect it from the motherboard.
  3. Asus X55C HDD (Hard Disk Drive) Replacement: passo 3, immagine 1 di 1
    • Remove the two Philips screws and separate the HDD from the caddy case.
    • You can install 2.5" SATA HDD, 5400rpm / 7200rpm, 320GB / 500GB / 750GB /1TB.
    • After changing / upgrading the HDD you must install an operating system or clone & copy the information from the old HDD to the new one.
    • Did you do it successfully.
    • Please SUBSCRIBE to my channel ツ
Conclusione
Altre 4 persone hanno completato questa guida.
ZFix
Membro da: 12/09/13
191.278 Reputazione
330 Guide realizzate
Master Techs Membro di Master Techs
Community
322 Membri
2.528 Guide realizzate
Un commento
Were do you get the OS already installed on the drive. I have a Asus 550 with a 500 G and win 8.1. Looking to up grade to win 10 YES i have the GEO FORCE graphic card. Will I loose the use of the GEO FORCE. card. It has a i7 chip. And 6 g of line one cache would like to take to like 16 G… I would like to use the solid state hard drive. I understand it weathers bounces. Small slams and bangs better than the disc type. But I may not beable to afford this high a upgrade. Recommendations chrisdeiotte7@gmail.com
Chris Deiotte - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 26
Tutti i Tempi: 11,401
