Introduzione
This guide will step you through replacing the battery in the Asus X555LA.
Cosa ti serve
Remove the following Phillips #0 screws from the lower case:
Six 9 mm screws
Four 11 mm screws
Altre 33 persone hanno completato questa guida.
10 Commenti
If the Asus f555la battery is buying at Chennai,if any availability?? Response to ashokkumara24@gmail.com.
Hmmm. A couple of the screw lengths look a bit suspect. At step 1, the six 90mm screws? That’s nearly four inches long!! And at step 6, three 50mm screws? I haven’t started this yet, but my guess is that the respective lengths should be 9mm and 5mm respectively. But apart from that, the article reads very well; just what I was looking for. Thanks!
MY PROBLEM ……THE BATTERY HAD GROWN….INFLATED ITSELF…AND IN SO DOING, ELEVATED THE KEYBOARD AT THE LEFT HAND SIDE, AND PREVENTED THE LID/SCREEN FROM CLOSING EVENLY.THE BATTERY ALTHOUGH BLOATED,WAS STILL OPERATING OK & WAS NOT LEAKING….. James King - 23/02 2018
