Introduzione
Removing the keyboard plate cover will allow access to all internal components of the laptop.
Cosa ti serve
Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
Two 9.5 mm screws in the middle of the back edge, and one 9.5 mm screw in the right edge
Two 4.3 mm screws in the back corners
One 17.5 mm screw at the left edge near the optical drive
Three 4.3 mm screws in the front edge
Invert the laptop in order to gain access to the ribbons.
Remove each ribbon by flipping the small white plastic flap up and gently pulling on the ribbon.
Now that the ribbons have been detached from the bottom cover, carefully remove the keyboard plate cover. Once it has been removed, place it in a safe and moisture free area so it does not get damaged.
Yes and you have to put lotion on
Now, that is a stupid question! Of course! As I am working on 551M, I naturally have to have nails painted orange, with blue accents!
that boy ain't right
Altre 11 persone hanno completato questa guida.
2 Commenti
WARNING the screw lengths in step 1 are wrong. I tried installing the wrong screws and now my touch pad us ruine
The screw info has been updated. I’m still not sure if it’s 100% correct, so be sure to keep your screws organized and put each one back where it came from to avoid damage.
screw assignments are definitely wrong. I swapped the red and the green, as per comment above, and kept the blue as-is.
jasonbuechler - Replica
jason is right
starwilson - Replica
correct, swap the green and red
Josh - Replica
Jason is correct
Clem Lanoe - Replica
Thanks everyone. It does seem like someone got their screws mixed up when they wrote this guide. I’ve made some changes as you all suggested, so the screw placements should be more accurate now. If anyone with this laptop could verify the screw measurements with a digital caliper, that’d also be very helpful.
Jeff Suovanen - Replica
