Introduzione
Removing the keyboard plate cover will allow access to all internal components of the laptop.
Cosa ti serve
Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
Two 9.5 mm screws in the middle of the back edge, and one 9.5 mm screw in the right edge
Two 4.3 mm screws in the back corners
One 17.5 mm screw at the left edge near the optical drive
Three 4.3 mm screws in the front edge
Altre 11 persone hanno completato questa guida.
2 Commenti
WARNING the screw lengths in step 1 are wrong. I tried installing the wrong screws and now my touch pad us ruine
The screw info has been updated. I’m still not sure if it’s 100% correct, so be sure to keep your screws organized and put each one back where it came from to avoid damage.
