Salta al contenuto principale
Asus X551CA Keyboard Plate Cover Replacement
Cosa ti serve
  1. Asus X551CA Keyboard Plate Cover Replacement, Keyboard Plate Cover: passo 1, immagine 1 di 1
    • Power off and unplug your laptop before you begin.
    • Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
    • Two 9.5 mm screws in the middle of the back edge, and one 9.5 mm screw in the right edge
    • Two 4.3 mm screws in the back corners
    • One 17.5 mm screw at the left edge near the optical drive
    • Three 4.3 mm screws in the front edge
  2. Asus X551CA Keyboard Plate Cover Replacement: passo 2, immagine 1 di 1
    • Use the plastic opening tool to separate the keyboard plate cover from the bottom cover. In order to do this, insert the plastic opening tool in between the keyboard plate cover and the bottom cover, then slide along edges to pry open.
  3. Asus X551CA Keyboard Plate Cover Replacement: passo 3, immagine 1 di 1
    • Locate the three ribbons connecting the keyboard plate cover to the bottom cover.
  4. Asus X551CA Keyboard Plate Cover Replacement: passo 4, immagine 1 di 3 Asus X551CA Keyboard Plate Cover Replacement: passo 4, immagine 2 di 3 Asus X551CA Keyboard Plate Cover Replacement: passo 4, immagine 3 di 3
    • Invert the laptop in order to gain access to the ribbons.
    • Remove each ribbon by flipping the small white plastic flap up and gently pulling on the ribbon.
  5. Asus X551CA Keyboard Plate Cover Replacement: passo 5, immagine 1 di 1
    • Now that the ribbons have been detached from the bottom cover, carefully remove the keyboard plate cover. Once it has been removed, place it in a safe and moisture free area so it does not get damaged.
Conclusione
Altre 11 persone hanno completato questa guida.
Josh
Membro da: 04/10/14
2.958 Reputazione
12 Guide realizzate
Cal Poly, Team 7-22, Regan Spring 2014 Membro di Cal Poly, Team 7-22, Regan Spring 2014
CPSU-REGAN-S14S7G22
5 Membri
15 Guide realizzate
2 Commenti
WARNING the screw lengths in step 1 are wrong. I tried installing the wrong screws and now my touch pad us ruine
Joe Allen - Replica
The screw info has been updated. I’m still not sure if it’s 100% correct, so be sure to keep your screws organized and put each one back where it came from to avoid damage.
Jeff Suovanen -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 17
Tutti i Tempi: 5,073
