Salta al contenuto principale
Asus X550ZA-SA100603E Hard Drive Replacement
Cosa ti serve
  1. Asus X550ZA-SA100603E Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Remove all of the 10 bottom case screws.
    • Seven of them are 14 mm screws.
    • Three of them are 4 mm screws.
  2. Asus X550ZA-SA100603E Hard Drive Replacement: passo 2, immagine 1 di 1
    • After the screws are removed, gently turn the computer to its upright position and open up the computer flap.
    • It is important to do this gently, as these pieces are loose.
  3. Asus X550ZA-SA100603E Hard Drive Replacement: passo 3, immagine 1 di 1
    • Pry open a gap between the keyboard and the lower piece using a spudger.
    • This will uncover all of the internals in the laptop itself.
  4. Asus X550ZA-SA100603E Hard Drive Replacement: passo 4, immagine 1 di 1
    • Slide the hard drive out of its position to allow room for the new one.
    • Make certain the area is clean and no debris got into the slot.
Conclusione
Altre 2 persone hanno completato questa guida.
Paul Flynn
Membro da: 01/14/19
16 Reputazione
2 Guide realizzate
IUPUI, Team S5-G5, Wilson Spring 2019 Membro di IUPUI, Team S5-G5, Wilson Spring 2019
IUPUI-WILSON-S19S5G5
3 Membri
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 11
Tutti i Tempi: 465
