Salta al contenuto principale
Asus X550ZA-SA100603E Battery Replacement
Cosa ti serve
  1. Asus X550ZA-SA100603E Battery Replacement, Keyboard: passo 1, immagine 1 di 1
    • Using the Phillips #0 screwdriver, remove the seven 14 mm screws on the bottom of the laptop.
    • Then use the Phillips #0 to remove the three 4 mm screws on the bottom of the laptop.
  2. Asus X550ZA-SA100603E Battery Replacement: passo 2, immagine 1 di 3 Asus X550ZA-SA100603E Battery Replacement: passo 2, immagine 2 di 3 Asus X550ZA-SA100603E Battery Replacement: passo 2, immagine 3 di 3
    • Insert a plastic opening tool between the keyboard and base of the laptop to pry the keyboard away from the base. Do this around the entire perimeter of the laptop.
    • This disconnects the face of the keyboard. Gently lift the keyboard up to expose the motherboard.
    • There are still ribbon cables connecting the keyboard face to the motherboard. Do not pull the keyboard away roughly.
  3. Asus X550ZA-SA100603E Battery Replacement: passo 3, immagine 1 di 3 Asus X550ZA-SA100603E Battery Replacement: passo 3, immagine 2 di 3 Asus X550ZA-SA100603E Battery Replacement: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Gently lift the keyboard to access the three ribbon cables connected to the motherboard
    • Using precision tweezers, flip up the white and black retaining flaps on the ZIF connectors that hold the two smaller ribbon cables in place.
    • Gently pull the ribbon cables from their sockets on the motherboard.
  4. Asus X550ZA-SA100603E Battery Replacement: passo 4, immagine 1 di 3 Asus X550ZA-SA100603E Battery Replacement: passo 4, immagine 2 di 3 Asus X550ZA-SA100603E Battery Replacement: passo 4, immagine 3 di 3
    • Push the two white clamps on the large ZIF connector towards the screen.
    • Gently remove the track pad ribbon cable from its connector.
  5. Asus X550ZA-SA100603E Battery Replacement: passo 5, immagine 1 di 1
    • Remove the keyboard.
  6. Asus X550ZA-SA100603E Battery Replacement, Battery: passo 6, immagine 1 di 2 Asus X550ZA-SA100603E Battery Replacement, Battery: passo 6, immagine 2 di 2
    • Disconnect the multi-wire battery plug from the motherboard.
  7. Asus X550ZA-SA100603E Battery Replacement: passo 7, immagine 1 di 3 Asus X550ZA-SA100603E Battery Replacement: passo 7, immagine 2 di 3 Asus X550ZA-SA100603E Battery Replacement: passo 7, immagine 3 di 3
    • Pull the two tabs holding the battery in place and lift the battery up. It should remove easily.
Conclusione
Altre 6 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 18
Tutti i Tempi: 6,149
